1 - 9 of 9 Posts
I have orderd some LED signal lights for the rear. I know that i will need to add some resistors but do not know what size. The bulbs are 21watts. any info will help.
If you replace the front and rear signals with LED's you usually do not have to add resistors. I would go that route. The resistors are known to get hot. I am looking for front and rear, haven't found any I like yet. What did you order??
There is 2 ways to go.
The stock signal flasher is load dependent meaning that if you install LED's that draw less current the flasher will flash fast or not at all.
To over come this you can add a load resistor to compensate for the loss in resistance
or
replace the signal flasher to one that is not load dependent and save energy in the process.
I have not seen a wire diagram or even a parts breakdown fiche yet for the furry so I have no idea what style it has but my guess is they would be using one of the 9 pin ones like the newer vtx's
Kisan Signal Minder
1 - 9 of 9 Posts
