1 - 5 of 5 Posts
So I'm having a little trouble with my LED tail light. I installed it last week, and for some odd reason, my front right turn signal flickers sporadically (they're also LED strips) or it's just solid amber, alongside the signal indicator. When I unplug my rear light, the front signal go back to normal. If anyone knows of a solution, the help would be greatly appreciated. If yall have anymore questions to diagnose the problem, I'd be more than happy to answer. Thanks in advance
240686
240685
Did you change your blinker relay? If not there is a good possibility that there is unwanted voltage dumping into your tail light/ signal circuit. Check all of your grounds. LEDs operate on extremely small amounts of voltage. Check the wiring front and back to make sure you left and right F/R are operating on the same circuit.
Like @Furi15 mentions, the LEDs don't draw enough power to [technical stuff explained in other threads] and fire the relay, so you can use load resistors to suck more power, or a self-heating or a smart flasher unit. Another issue is LEDs light rather easily, so you might wind up with hazard flashers instead of directionals. For this there's a diode kit.
1 - 5 of 5 Posts
