Quoted For the truth!I still don't understand why ya'll want to lower your bikes more than they are......I scrape more than I want to and bottom out as well....even if I lowered my bike a half inch, it would be a lot worse.....you must have smooth flat roads where you live......![]()
Too expensive for my means........suspect that leakage might occur at onset or later and that would mean more headache and bucks for me.....appreciate the heads up though.air ride. either sumo als or platinum air. search at the top for air ride. this way you can be high as a kite when u want to and low and slow other times.
weight of you and or passengerthings to take into consideration
exhaust you are or are wanting to run
how aggressive you ride.
I mountain rode a lot before I even got the tree's and extensions on, didn't scrap ... but I think you're running cobra's? Even so, the above measures should help with the 3" extensions added onto the ride.I still don't understand why ya'll want to lower your bikes more than they are......I scrape more than I want to and bottom out as well....even if I lowered my bike a half inch, it would be a lot worse.....you must have smooth flat roads where you live......![]()
Do you scrape your frame or your pipes or foot controls ? When I lowered my bike I would scrape the shit out of my frame now I am back to stock and am so much happier .I still don't understand why ya'll want to lower your bikes more than they are......I scrape more than I want to and bottom out as well....even if I lowered my bike a half inch, it would be a lot worse.....you must have smooth flat roads where you live......![]()
TMOD then........I don't mind the ride the way it is just don't like the fender so far from the tirer. Kinda the dirt bike look . imo.
Its Mod to the sub frame of the bike that sets the fender to a lower angle to the ground making the bike look as if its lowered . Basically a do it yourself MOD if You know how to weld . MFR please chime in ...Ok not too sound like an idiot . What is a tmod
contact MFR....Yes i weld for a living . Can weld aluminum/steel/ stainless steel ...
