I want to lower my bike about an inch but am not sure how. There are the simple solutions for the rear end, L&M Shock or MFR Shock Mod, but there are no solutions I have found for the front end. My goal is to lower the bike an inch and keep it level, front and rear. Maintaining the bike's current level will maintain the trail of the front end and maintain the look I am working for on the bike. I have seen options for Harleys, a shortened front fork tube spring, but nothing for our bikes.
My thought is to cut the springs off about an inch. I wanted to get some tech opinions from you guys, especially those of you who are bike techs on this and whether or not it will even work. Pros, cons, impact to front suspension. My initial concern is that is will obviously reduce the travel of the front suspension and possibly cause it to bottom out.
What be be even better is if any of you techs have access to the specifications of the actual front springs (size, length, tension, etc) so I can possibly find an aftermarket option. The ideal solution would be a slightly shorter spring with a slightly higher tension to compensate for the reduced length.
Thanks for the feedback fellas.
http://cdn.cheapcycleparts.com/images/HO/14MFRA01/MFR4F0800A.png
