1 - 3 of 3 Posts
I picked up a power mod chip that needs to wire into the map sensor wiring harness. It says it needs the signal wire for the sensor (most likely red)
and the ground wire for the sensor (most likely black) does any one the correct color for sure? and the best area to work on to get at it?
I'd really be interested in some more info on your 'power mod chip' before I could recommend using it...
1 - 3 of 3 Posts
