you cannot put that tire on an 18 inch rim.metz makes a 210 18 for the fury.my rims are being chromed now and thats the way i will go when i get them back.Has anyone tried to the Metz 880 XXL 210/50/17 on the Fury?
Be sure to post pics.you cannot put that tire on an 18 inch rim.metz makes a 210 18 for the fury.my rims are being chromed now and thats the way i will go when i get them back.
460...I can't find that 18 inch metz. You sure it's a 210? The catalog only lists a 200 50 17. I want to get that 210!you cannot put that tire on an 18 inch rim.metz makes a 210 18 for the fury.my rims are being chromed now and thats the way i will go when i get them back.
what he said.210/40vr18 will go right on with no mods.its a little wider and about the same in hight.
IMO it is not worth it unless your 200 rear tire is sold or ready to be replaced anyway. If your replacing the rear anyway, why not go slightly larger. Just not worth dropping the money (again IMO) if you still have a good 200 rear tire. I will go to the larger tire when it is time if I have not already upgraded to the 250 by then.Is going from 200 to 210 much of a difference?
go to your serch engine and put in (metzeler me880 motorcycle tire).it will list all there sizes.Has anyone tried to the Metz 880 XXL 210/50/17 on the Fury?
Yea, it's a 200 that he has... we've compared them side by side as well, definitely looks wider too...Riding behind CB Fury and Trip this last weekend, he has a Metzeler on the rear and it looks wider than the (Trip) Dunlop going down the road.
I believe his Metzeler is a 200..
There was a difference from afar.
T
Yeah you are right on the width Tony... I am running the 200 for now. I am looking at doing the 210 here in another 1,000 miles or so... which will total over 10K miles on the Metzler... big difference in the ride as well. I use to feel road groves on the Dunlop and when I got the nail in it at 600 miles I went to the Metz and have been loving it ever since... just my opinion.Riding behind CB Fury and Trip this last weekend, he has a Metzeler on the rear and it looks wider than the (Trip) Dunlop going down the road.
T
Gar:Shane, I used to run Metzeler Comp K on my FJ which were good for only 3000 miles but very sticky. Loved 'em esp after removing the stock slippy tires.
Regarding your change up to a 210, it's a lower aspect ratio, 40 vs. 50, and may be noticably smaller in diameter and possibly not a good sacrifice for the extra 2/5" width. Please check and compare the two tires in the same condition (mounted or not and same wear).
210 on a fury.200 dun next to it.this is the reason i am going to the 210.200 or 210![]()
