I've read that a few of you have the mirrors w/ built in sigs. How are you running/hiding the power wires?
Have Demons Claw LED wires come out near bottom and used chrome tie wrap then wire goes into stock cabling harnessI've read that a few of you have the mirrors w/ built in sigs. How are you running/hiding the power wires?
LOVE the look...LOVE that I could remove the stock lolipops from the forks, but quite honestly, I can't see shit outta those mirrors! But I wouldn't trade them for bigger mirrors that give me better vision. I had a chance to put larger mirrors on but they looked like dumbo ears to me. I choose to look over my shoulder and be more alert.For those of you that have the mirrors from Demons ( the ones with the holes in the arm), hows your visibility? I have some ectenders installed also that push them outboard about 2" and up about 1". With my 8 deg trees all i can see is the ground about 10 ft behind me.
I think your problem will quickly go away if you loosen the two allen head bolts on the clutch and brake arm perch then tilt them all the way down so the mirror turns up for a better line of vision.For those of you that have the mirrors from Demons ( the ones with the holes in the arm), hows your visibility? I have some ectenders installed also that push them outboard about 2" and up about 1". With my 8 deg trees all i can see is the ground about 10 ft behind me.
I told him to do that. I also had to do that.I think your problem will quickly go away if you loosen the two allen head bolts on the clutch and brake arm perch then tilt them all the way down so the mirror turns up for a better line of vision.
