1 - 5 of 5 Posts
Looking to have a S & S representative answer this question:
Is the Mo-Flow Air Assembly (made by cyclevisions.com) compatible with the S & S air cleaner for the Honda Fury (since it is suppose to fit S & S Carbs) ???
The set up pictuted is for use with S&S Carbs. The Fury does not have an S&S Carb so this will not fit on the Fury.
What if the Fury already has the S&S Teardrop air cleaner and adapter already installed?
The S&S air cleaner for a Fury does not use an adapter; it bolts directly to the fury throttle body.
The filter you are looking at should work with my adapter or l&m’s adapter if you order the MoFlow filter for a Harley CV carburetor.
1 - 5 of 5 Posts
