1 - 20 of 24 Posts
Ohhh, you got the radiator cover that I want to get.... hmmm, looks good with the spoiler, was wondering about that... how they would look with the spoiler on, looks great!... How do you feel about that cover?
Like the risers.... Still not crazy about the pipes....
I think if he added a better air injector than the stock one, think it would deepen the sound on throttle? Don't know, like the sound of it when idling though... could be the sound clip itself breaks up a little bit. Don't know, maybe having somebody throttle it while he stands back so the dB doesn't affect the mic, might be a better indication of how they sound. Love the look of those pipes tho!
How did you get em out? Mine seemed like it would be more work than it's wrth. Did you notice much of a sound difference? Also are you using a programmer and if so did you have to change your settings?
Super sharp bike btw! I like where you put your plate.
Thanks!
Discussion Starter · #7 ·
I like the cover very well , fits real good . You do have to remove the spoiler to install it . Comment on the sound , try to get one with me rideing . Im waiting on the Lowandmean adapter,spike intake, and power commanderV
Discussion Starter · #8 ·
Sounds pretty good with them baffles removed. I had them out of mine but was told it would burn my pistons and valves any truth to this. I would prefer them to be out but dont want to screw my bike up.
Well Im sure theres some truth to that If it running to lean .I have a programer comeing to solve that and will only be putting a 100 or so miles on it before it arrives and installed. I have a 03 shadow 1100 with straight pipes and carb regetted 3 years now and no problems.
Discussion Starter · #9 ·
Thanks!
They are a little hard to get out .Some wd40 and cloths hanger did the trick. Sound different you bet , night and day. Proggramer is comeing. Thanks for the comment
For what it's worth i installed the fi2000r with mine and the bike stinks of fuel. The programmer is set at the recommended default. Also i went through a tank of gas in about 24hours.
I'm going to fill up again today and see how many miles i get before the next fill up.
fuel map
Did you take the bike in to have it dynoed or did you find a map out there for your set up? I am looking to run a very similar setup and think I could use the same map if it is out there or if you would like to share.
Discussion Starter · #17 ·
Have not seen a custom map , guess nobody willing to share . The cost of dyno tune I got was $350. So I have decided to get the PCV auto tune . On order . Also going to install two o2 sensers . Build a map for front cylinder , download to laptop , Switch sensers and then build a map for rear cylinder , download it . Hook laptop to PCV and program . The PCV will let you combine the two maps . If needed you just repeat again . PS .Once the PCV is programed like this the auto tune is disabled . But you can always enable it and auto tune anytime. And Yes I will be willing to offer the programed map's for anyone interested .
Discussion Starter · #19 ·
Do the cobras have a place for the o2 sensor to be installed? I see that Samson says that they have a place to install one but I don't see that stated for the cobras.
No they dont . I will have to pull the pipes off and install the o2 senser bunge on each pipe . Not that big of deal LOL . At least when all done should be a breeze to tune . If you cant weld yourself any muffler shop will do it for you .
I pulled my today and it sounds much better. Cloths hangers my a$$. I didn’t try the wd40 but it took a lot more than a little wire. The top pipe was in there really tight but the bottom came out without any problem. I think I read that someone posted that the top came out easy and the bottom was a pain in the a$$. You must have gotten lucky and both of yours were just ripe for picken:D
1 - 20 of 24 Posts
