my ride on the rack in progress being murdered out
Lol... see the progress? but an explanation of what you're planning is always nice....my ride on the rack in progress being murdered out![]()
Oh, nice... stealth install for the cables... can't wait to see what that looks like... been thinking about that for awhile now....If it was chrome I had it powder coated black if it was plastic it is black all cables will run threw the bars side mount plate led tern signal integrated in the mirrors led tail light thus far
Pull it out and replace it with a custom cap - im replacing mine with an iron cross capthe one mising link is the gas cap cant powder coat and pant will chip don't know any ideas
Mask-off the underside, bead-blast through the chrome, then paint. The paint is not likely to chip when applied to a bead-blasted surface, if you don't put it on too thick.the one mising link is the gas cap cant powder coat and pant will chip don't know any ideas
Don;t know if this helps you but I've taken theses measurements already.Mask-off the underside, bead-blast through the chrome, then paint. The paint is not likely to chip when applied to a bead-blasted surface, if you don't put it on too thick.
On another note, since you have your header pipes off, could you take a caliper and measure the exhaust port diameters (front and rear), right where they exit the heads and meet the header pipes? I'd appreciate the favor.
