1 - 11 of 11 Posts
I am looking for some feedback from users that have installed a side mount license plate with the light.
What I want to know, is if you ran the light wiring inside the out drive or not?
I'm a little concerned about the drive shaft catching the wire.
I ran a flexible plastic tube on top of the out drive but hate the look of it.
(It's got to go..):mad:
(see pic)
I would appreciate everyone's feedback
Thanks in advance..
Tony
3M fixes all!!!!!!
What i did with mine is ran the wire underneath and held it up with some 3M tape u will never see it or even know its under there and have not had a problem with it at all the only wire u see is right at the light.
Discussion Starter · #8 · (Edited)
Thanks, all good feedback.
Underneath is the way to go.
That black plastic flex tubing run's up under the fender to the rear old license light connector.
Rear modification pic
Going to try that double sided 3M tape suggested and see how it holds.
Then onto the silicone sealant if that doesn't work..
Thanks for the replies.
1 - 11 of 11 Posts
