UPDATE [ISSUE SOLVED]: See reply further down this page for pictures/video. After ripping some of the wiring out, I found that the previous owner did indeed install a dual circuit for the LED strip taillight. With some testing, I learned that the new Custom Dynamics LED run/turn/brake lights were not dimming from brake to run because there was not enough resistance in that circuit. The resister that was in the dual circuit for the LED strip was only something like ~45 ohms. This was enough to dim the LED strip, arguably not enough, but not enough to dim the new LEDs. So, I created (2) new and separate dual circuits for both of the new Custom Dynamic lights - each with a ~600 ohm resistor. While I was at it, I replaced the resistor in the LED strip circuit for something higher, so it has a greater difference between the run and brake light. The difference will make my brake more visible. Yay safety. Now the lights are dimming properly. Instead of just throwing the wiring together, I created a custom harness from scratch (as shown in the first pictures in reply further down this page). Everything was soldered together, shrink wrapped, and then cable wrap put over that. The harness has:
(1) 5-pin connector for the main harness
(1) 4-pin connector for the rear LED strip
(2) 3-pin connectors for the 2 turn signals
Hello all!
I recently purchased new dual-color LED lights for the front and rear in hopes of increasing visibility on the road but can't seem to wrap my head around getting them to work correctly. I've done extensive searching through old posts but at this point I need someone much more knowledgeable than myself. I purchased the following:
Below is what the current harness in the rear looks like. It appears to go from a 5-wire down to a 4-wire which I can only assume is the BRAKE/RUN wires being spliced together in some fashion. When connected to the Chrome Glow LED, it works as intended although the RUN light could be a bit dimmer.
Took off the electrical tape and dug down a bit more to see what was really going on:
The new, 3-wire dual-color (red/amber) LED for the rear shown below. When I tried the below connections, the red run shines brightly (like brake bright because I assume it is not dimmed properly) and the turn signal works but I never can get it to dim to a RUN light.
Custom Dynamics RUN/TURN/BRAKE ---> Wire harness shown above
red --> red
black --> black
remaining --> one of the turn signal wires from the harness
I'm happy to purchase a module of sorts it that would make this more plug-and-play or build my own harness if someone can point me in the right direction. I truly appreciate the assistance with this headache!
Current Chrome Glow LED function:
Hello all!
- Custom Dynamics Micro Bullet LED Turn Signals: Dual-Color (red/amber), 3-wire for RUN/TURN/BRAKE in rear
- Custom Dynamics Micro Bullet LED Turn Signals: Dual-Color (amber/white), 3-wire RUN/TURN in front
red --> red
black --> black
Rich (BB code):
20230301_130802 by itsmeryanb, on Flickr
