1 - 6 of 6 Posts
While riding home I realized this screw had fallen off from my clutch lever. I'm wondering what part number it is and where I can order it.
From what I have been hearing about BikeBandit, they are getting kind of lackadaisical about order fulfillment. Might want to look at Revzilla or Cheap Cycle Parts.
I went ahead and stepped it up a bit and looked up the # for the brake side. The pivot bolt is different but the nut is the same.
So don't bother removing the brake bolt to match it up at the local hardware. It would be a bummer to have the clutch side loose and vibrating or worse sticky.
If you special order the OEM bolt might as well order the OEM nut to keep the assembly in its original fit and finish in my opinion.
BTW, did it really back out on its own or did someone misplace it ??
Reactions: Furi15 and Gizmo
1 - 6 of 6 Posts
