1 - 7 of 7 Posts
So went by my local dealer to get some rear brake pads and sat on the new line up. Did not really like the Interstate or Sabre, but the Stateline was nice with the floor boards. Now to my question... Does anyone know if the peg brackets on the Interstate or Sabre are the same as the Fury? They curve out a little and are color matched to the bike. Maybe one of the guys from parts direct or something can compare the bolt alignment when they get a set in. Just food for thought.
On a side note... got 15,553 miles on the first set and most likely could have gotten another 2k or 3k more before they had to be absolutely replaced. They where about 80% gone. They where real easy to replace, just a lock screw and then the pin screw and out they came. Then pushed in the caliper piston and the new pads went right in... just incase anyone was wondering.
Not looking for the floorboards Goober... asking about the ones for the other two bikes... but if they will work then I am sure the Stateline floorboard would work as well... they are mounted with two bolts up front and then come back with a heal to toe shifter... :p
The Interstate is the one with the boards, the others may work but since they (the controls) are set out and back more than the Fury it might take quite a few more parts than just the mounts. (linkages and such, and the horn mounts and horns are diff, so that may have to be changed also)
Discussion Starter · #5 ·
Ok... plan on changing to a air horn and mounting it out of site so no worries there... as for the linkage I can do that... just wondering about the bolt pattern.
I took some quick measurements, the Furys appear to be about 5mm closer together at the mount holes center to center. They just seem black on the ones I looked at, not the same color as the tins, except the black one.LOL. You could powdercoat or paint yours alot easier IMO.
Discussion Starter · #7 ·
Thanks Clueless... That was what I was looking for.
1 - 7 of 7 Posts
