1 - 17 of 17 Posts
Got my miniapes from FMB Choppers on today. Seemed comfortable on the 45 minute ride home today. Had to add 4" to the brake line and reroute the others. Also moved the speedo to the top of the ignition cover. Adding a 30" sissy bar this weekend for the old school chopper look.
Those are really the only "ape" style bar's I've seen on a Fury that I like
Not bad. I have been considering some myself. Where is the sissy bar coming from. I hate my oem , but refuse to pay all the money someone like ginz is asking.
Discussion Starter #6
I've been thinking about that.... What are you thoughts on the speedo relocation?
I know STG makes a side mount to go above the intake but I wanted it on the other side to balance out the look. Ended up mounting it to the ignition cover. It's solid and doesn't move. Had to extend a wire.
Discussion Starter #7
Agree in the price for Ginz. I'm sure the quality is great but there is a ton of markup. I got a 30" cycle visions sissy bar off eBay and will fab a mount. I only ride solo, so it's just for an overnight bag.
What are the adapters you're using for the bars? I'm really interested in your set up!
What's the hight? I'm thinking I could go for 10" Apes.
Thanks in advance for your help.
Discussion Starter #9
I've got 11" FMB Choppers mini apes and 1 1/2" LA Choppers risers. Anything taller than this and your replacing all cables. With this setup I only had to replace the brake line +4"
Looks really great. I know someone on the fb group changed his and used a digital speedo. Looked killer. I'd go that route with your apes. Very sexy.
The speedo is a motogadget mini, btw.
Hello - I read this thread a year ago and I have finally found it. I am curious to know if the break like you had to replace was the front or the rear break cable. I love the look and I think I have decided to do something similar. Just ironing out all the details to start purchasing the parts. Thanks!
Rear brake is actuated by your right foot!!!!!
Excellent, I like the apes and the pipes. I’ve thought about welding a cross bar low on the apes and keeping the speedo there. It’s on my list ?
I'm looking at my computer screen at fmb bars and can't decide on height 12" sounds right. I'm 6'2" and want to lean back a bit with my duffle against my sissy bar. Bad back. Any suggestions? Oh, 2015 Fury.
Question. If I’m only adding 3” riser do you think I’ll need to add or replace my cables?
1 - 17 of 17 Posts
