New Owner putting downed bike back together
225 Views 12 Replies 4 Participants Last post by  bdmaximusthe1st
I just picked up a wrecked 2016 Fury after speculating on buying one for years.
Tank and fenders, all the lights and possibly the front wheel are damaged. It's still mechanically sound from what I can tell. I did figure out the previous owner had left the forks just loose enough to cause an alignment issue. I strapped the front wheel to a post in my shop to hold it upright, and when I went to move the bike to straighten it, the bars actually moved to where they needed to be. I still have lots of things to do. I'll be posting pictures here and I'm sure I will have questions from time to time.
They day I went to look at it:
Sent from my motorola one 5G using Tapatalk
View attachment 246425 View attachment 246426 View attachment 246427 View attachment 246428 View attachment 246429
  • Wow
Reactions: 4
1 - 13 of 13 Posts
2
The ride home and after taking it through the car wash. Bike has LED accent lights. I'm not sold on them, but they do have a handy key fob.
View attachment 246422 View attachment 246423 View attachment 246424
Reactions: 2
3
I apparently didn't take any pictures of the broken fenders. I don't know what I intend to do for fenders in the long run, so I thought I would mess with these to see what I could do with them. I am NOT a body guy. I saw a video of a device that heats wire clips and allows them to sink into polymer body parts to reinforce repairs. I decided I would recreate this with parts I had on hand. It worked well e ough for my needs, but not well enough to do for someone else.
I used an M18 Milwaukee battery, a starter button used for cranking engines without the key, and a home brew battery adapter made from an M18 flashlight. My first attempt didn't use the momentary switch, so temp skyrocketed and the polymer burst into flames. The switch allows the current to be modulated and thus controls the temp of the wire.
After that, I sanded with an abrasive wheel, troughed the fracture a little and covered all of it in JB weld Plastic bonding epoxy. I did this to have some flexibility. I had four fractures total, two on each fender.
I also cut the damaged portion of the front fender off and fashioned it into a point.
I reinstalled the rear fender just to get a feel for it and what I wanted to do about the rear lights.
Hood Automotive tire Car Automotive lighting Motor vehicle
Hood Motor vehicle Automotive lighting Automotive tire Automotive exterior
Hand Watch Gesture Finger Drinkware
Reactions: 2
I don't think I plan to actually paint the fenders, I've ordered Nardo Grey vinyl and a black hexagonal pattern vinyl.
The next big hurdle is the beat fuel tank. I told myself that I would pull it when the fuel got low, but I topped it off and went for another spin this evening. I guess I will just have to keep riding until the light comes on again
Reactions: 2
Someone is gonna have to explain how to get photos to post from Tapatalk without it linking attachments. I tried to edit the first two but the attachments persist.
Reactions: 2
Welcome from Alabama. You have a good canvas to start making it your own. Good luck with your ideas and keep us updated.
Reactions: 3
Welcome from Pennsylvania. At first glance from the rear photo the bike looks crooked. Have u checked the frame alignment?
Reactions: 2
I haven't yet. I will have to research how to go about that. I don't see enough impact damage for it to have been able to bend the frame. That tail light assembly bracket is trashed and skews how the rest looks to some degree.
Reactions: 2
I adjusted the shifter linkage so I could get my size 14 flipper under it and ride without having to point my foot forward at an awkward angle. I didn't take a picture, but I did find that the screw that held the cover on was bent. I was shooting for the same place as the brake lever but went too far.
I looked at the tail light assembly again. One of the front turn signals is salvageable so I will swap it to the rear assembly. I'm going to salvage the assembly and utilize it until I'm ready to buy a wrap fender with led lamp.
I have a plan for the front that may not make many fans but it will be different. Should have something worked up by the end of next week.
Reactions: 2
4
So I went ahead and disassembled the tail light assembly. You can see the bracket has been pulled to one side significantly.
I killed the rubber bushing on the damaged light before I realized how they come apart. The silver sheet metal based in the center forms a clip that anchors the rubber bushing into the chrome housing. It's removed by pulling out two Philips screws. Once that is out, the bulb contacts are free to move. The wires have a molded plug around them that engages to anchor the rubber bushing I to the housing. At the other end of the wiring, you just pick the two tabs on the connector body and pull the wires out the back. The light housing on the front of the bike is a 3 wire. I simply clipped the unutilized wire and left it tucked inside the sheathing of the wiring. I'll post pics of things assembled once I beat the bracket back into persuasion.
Wood Flooring Floor Hardwood Wood stain
Automotive tire Rim Bicycle part Gadget Automotive lighting
Circle Automotive wheel system Auto part Thumb Metal
Finger Wood Thumb Nail Tool
Reactions: 2
Welcome from Ohio. That looks like a great project.
Reactions: 2
3
I beat that bracket back into submission this morning and reassembled for fitment. I will see how it fits on the bike this evening. It looks fairly true right now, with all the bolt holes aligning with the holes in the plastic. I think it might need one more yank once it's bolts back on to the fender structure.
Wood Table Wood stain Flooring Floor
Reactions: 5
My first attempt at vinyl didn't go as planned. I over stretched which caused it to lose its tack. I'm torn on whether do go with the nardo grey as it looks similar to the OEM color that was offered and not exactly what I was after. Shipping apparently lost my other roll of vinyl so no clue when that will be here.
Reactions: 2
1 - 13 of 13 Posts
