ill be picking up my new fury this week and im sure this question has been answered before.
i did the search button but still inconclusive...
the goal is to add a 250 rear long term but short term...
whats the widest rear tire i can put in the rear without having problems
mark
This is taken from the section "Fury Faq" on the blue bar at the top of the forum page.
Q: What is the biggest tire I can use on the stock Fury?
A: Safely, 210mm is the widest. 220mm with modified rim, read on.
A1: (***)Since this is a user made FAQ, I can honestly tell you that the 240/50/18 is the biggest size you can use on a stock Fury tire, it is a small rim, big tire combination*** but there will be minor issues with bolt and nuts not fitting that you may have to deal with. THIS is a mod to use at your own risk.(***) This will bulge out your tire, which is a safety risk and there are only currently less than 5 riders with this particular mod that are "known. YouTube - Honda Fury with the 240 Rear tire video As said in the video if you are still reading, 19mm, 14mm, for the stock 200mm tire and 13mm, 10mm for the 240mm tire. So, that will make it 210mm or so after this install.
A2: The 210mm rim will fit on the stock rim, but may look thinner than the stock tire, because of the height and general "shipped" width of the tire. If you refer to answer A3, you will see if you widen the rim, then add the 210mm tire, you will get the 209+mm tire that you are looking for.
A3: 250mm, with the Sumo-x version. This proven method to widening the tire is the Sumo-x version and looks good! But, this version will cost you $3,000+ for the WHOLE kit. You can order these in segments, which could be cheaper in the long run, determining on what you add. Here's the link: MeanCycles - HONDA - FURY 1300 - 250 FAT TIRE KIT FOR HONDA FURY and this thread here:
http://www.furyforums.com/forum/fury...-tire-kit.html
A4: Another method described by Low and Mean, would be that of widening the stock or aftermarket rim to a MAX of 7", the current stock rear rim is 6.25" wide. This will allow for a 240mm tire to go on to the modified stock rim, but the total affect will measure at 220mm. This is a safer version of my A1 answer. The rim widening would be through Kosman.net or another wheel widener and takes 4-6 weeks to do (this is do to buyer-backup, damn Harley riders). If you have the free time, try this mod out. Most it will cost you is about $850 (if you have the right connections) with the stock rim, tire and all. Link: 240 tire on a Modified stock rim VIDEO
A5: Stock Fury rim with Sumo Fender: Sumo-X fender with stock tire
I would suggest any new owner look it over, it has a ton of info in it. Also grats on the new bike, your gonna love it. post some pics
