Thanks to Red for the step by step. Instead of using LED strips, i went with stalks with a clear lense.
After tooling around with the stockers, i finally figured out that the black housing on the front is one piece of rubber. I ended up cutting off the part that holds the stock lollis on, boring out the center to hold the nut, wired it and and man what a difference.
i had to do some modification to the rear as well, but i made it fit, and thats what counts.
Now im not sure if this has been covered, and i think it has. But since replacing the bulbs with LEDs, all four corners are on constantly. And, the indicators under the speedo are always on as well. Im guessing that there isnt enough load on the circuit to shut them off? I really dont mind though, cause riding around here in the city, ill take all the extra light i can.
