1 - 8 of 8 Posts
I am sure that there are still 2. I don't think that Honda has made ANY mechanical changes to the bike other than to make you buy the passenger seat and pegs from the parts department. Look in the relevant section of the repair manual, found here Repair Manual Uploaded Link , and do a visual comparison. I bet you will find that there are 2 on your 2019.
On my 2010 there are two - one facing down (to the pavement) one facing forward (to the front wheel). The one facing forward will drain a little oil, and the one facing down will drain most of the oil. It’s by the oil filter. Hope this helps.
Discussion Starter #5
By the way, would u happen to know the crush washer size for the drain plugs. thought i saw 12mm. But my local auto store has different thickness
It is 12mm, but I’ve had some that don’t fit. Check out partzilla. They have exploded diagrams of OEM Honda parts, and you can order that specific crushwasher.
236769
It’s #28 in this diagram. Guaranteed factory OEM fit. Check em out.
1 - 8 of 8 Posts
