Trying to install the right side foward control and I need to get the radiator to move out a bit. Which bolt or bolts is it? The other three that I can find have rubber bushings. Help before I get the torch
If I recall properly, you're dealing with the bolt that holds the old master cylinder? I just kept unscrewing it with a box wrench and wiggled it out of there. Very tight quarters.DLx and its the plate that the cyl. mounts to the bolts to take it off are directly behind the bolts that hold the stock controls on. They will not come all the way out, because they are hitting the radiator. I just dont see or am overlooking the right lower radiator mounting bolt.
