RY. When you painted did you use the 'spray cans' from colorrite or the quarts????
As I have stated in past posts, colorrite is not the OEM paint for the fury but has a very close match.
Similar to purchase of Dupot for a Harley-- They don't make the paint but that can cross-reference the color. The Candy is simply an intercoat clear with Candy color added. This is a hard system to match when painting. The metalic base coat has to have perfect covering and then the candy gives the color sheen to the base.
I am suprised that the candy is covering up the metallic with such intensity. Usually, the candy will bring out the met. in the base. If you used the cans, it will be much, much harder to match as the propellant acts as a contaminate at times and the flow is just not as uniform as with mixed/sprayed paint.
You did a great job considering the difficulty in this finish. The Blue is the only Tri-Coat color in the Fury Palet. None of the local paint jobbers have the formula yet. Colorrite had experimented enough to get the closest match for paint so far.
I do, however have the met. Silver code from PPG. I will post it on that thread for anyone needing it. They are still working on the other codes. The Silver is a "perfect" match and I will be sending them parts of the other colors to scan and formulate but at 30 degrees and a couple of inches of snow on the ground, I can't say when that will be.
Hat's off to you on your paint. Always looks better in person than on a pic.
