1 - 4 of 4 Posts
Aloha again I was just wondering if someone could tell me witch hose in the back of the stock air box do I plug in order to make the pair valve inoperable I just wanna do this test first before ordering block off plates and doing the actual proper block off thank you hope somone can help thank you
Discussion Starter #2
Hey crash you the fury guru can you please tell me what hose to plug in the back of the air box to make the pair valve stop doing what it dose just as a test before getting actual block off plates
That's your PAIR setup. Keep the breather to your intake. Hose (4) goes to your intake from the PAIR setup. That's the one that gets taken off. But you need to block off both valves. You can stick bolts in the hoses as a quick fix.
1 - 4 of 4 Posts
