AS PROMISED "PAIR VALVE REMOVAL"
For all those wishing to remove the PAIR solenoid and plumbing from your FURY here are a couple of photos of what the REED covers look like and also a picture of the solenoid and its associated air pipes.
The pictures show the bike with the PAIR solenoid removed and the bolts screwed into the REED covers to block them off. I used a 7/16 UNF because I happen to own a set of UNF taps, but any 7/16 thread would do. I have numbered the parts on the photos and labeled them under each photo.
1. FRONT CYLINDER REED COVER.
2. REAR CYLINDER REED COVER.
3. AIR CLEANER BLOCK - SPIKE AIR CLEANER.
4. PAIR SOLENOID & PIPES (Remove all this)
Now you have all seen the pictures get out into the garage and start work.
To remove the solenoid you will have to take the tank off.
1. (2 person job here) Undo the 10mm bolt at the rear base of the tank (presume your seat is already off). Remove the bolt. Lift the rear of the tank up about 2 inches and slide it to the rear about 2 inches. Lift the front of the tank up to access the wires under it. Do not disconnect the fuel lines just the wires to the fuel gauge. Carefully swing the tank around 90 degrees to the left of the bike and have the wife or a mate hold it or better still have something there to sit it on. I wrapped a towel around the base of the tank to stop it rubbing on the frame etc.
2. Remove the chrome covers on top of the cylinder heads and whatever other covers you need to remove from around your air intake to access the PAIR valve which sits between the frame rails above the front of the rear cylinder (hope that makes sense).
3. Disconnect the pipes from the REED housings and the air cleaner. Remove what pipes you can from the PAIR solenoid.
4. Using an 8mm socket on an extension go down from on top of the frame and undo the one bolt holding the PAIR solenoid in place.
5. You should be able to wriggle and manipulate the solenoid out across the top of the injectors, on the way out unclip the electrical plug from the PEAR solenoid, the lead is about 6 inches long. I managed to remove the solenoid with the front cylinder pipe still attached.
6. Now remove each of the REED covers, 2 x 8mm bolts, and either thread and fit the bolts as in the photos (this is a temporary fix until my plates arrive from the USA) or replace them with the Block Off plates that you should have ordered before hand. To keep it simple get the dimpled plates here; BLOCK OFF PLATES
HINT: The rear REED cover is a real pain to replace with the tank bolted in position, best access is through the frame with the 8mm socket and extension so suggest you come prepared with the new plates to save taking the tank off twice.
7. Bung up the hole left in your air cleaner. Too many different possibilities here so you will have to work this out for yourself, there is no pressure on this bung you are just stopping the dust and crap from being sucked into your engine.
8. Cable tie the 6 inch plug from the PEAR solenoid back to the main loom.
9. Put the tank and seat and covers all back on and start your engines.
You should be done if you have made it this far, one of the easiest jobs without a great deal of mechanical knowledge required.
