ok for those with the Power Commander 5, there has been some updates done, First off, there is the Auto tune, witch has been out since the PC5 came out for the fury, And now the IGN, module add -on. this add on module will let you advance or retard IGN, timing.
the unit sells for around $350. its plug and play,
also with a dyno, you can really get IGN timing dialed in to increase throttle responce, HP and TQ. plus also smooth out the engine. you can tune both cylinders together or by them selfs, just like the Fuel settings. this lets you balance out the cylinders for peak power and smoother power curve.
this add on is for the tuners looking for the most out of there power mods,
SO if you have put the PC5, pistons, cams, head porting, high flow intake, High flow exhuast, now you can get most out of it.
this spring, ill Be getting some dyno time, and will be testing and making maps.
