Was that because you didn't replace the old ones....?Didn't even notice.
The gaskets are compression fit into the exhaust ports.To answer the gasket thing....They weren't on the pipes so I assume they were still in the head and nothing was broke, so I put the cobra right on without issue..The bike only has 80 miles on it so I assume they will still be good.
As far as the sound difference??? The Cobras are a lot deeper and throatier. The Raws sounded good and were loud, but I like the low rumble of the Cobras.
It wasn’t too hard. I cut a notch in the short angle of an “L” shaped Allen wrench. Attached vice grips to the long end and threaded a big bolt onto the handle end of the vice grips. I had a heavy weight with the center drilled out that I slid over the bolt and put a stopper nut in the end. I then could hook onto the baffle and hammer it out.How hard was it to get them out?
I don't know what you just said.It wasn’t too hard. I cut a notch in the short angle of an “L” shaped Allen wrench. Attached vice grips to the long end and threaded a big bolt onto the handle end of the vice grips. I had a heavy weight with the center drilled out that I slid over the bolt and put a stopper nut in the end. I then could hook onto the baffle and hammer it out.
I don't know what you just said.![]()
yeah but im sure your emission laws are different,,I was trying to help my friend Ron,,who thought the sut was brake dust,,IM not sure I want to keep taking my baffles in and out every year unless I register it in a state that doesnt have emission laws,,so knowing what you said and how confusing it sounded to take them out and not having the knowledge of doing it,,I might refrain at this time. Ill just keep taking notes from all you baffle salts til I can understand it.WildBill, I contacted Cobra about the Fi2000 settings being all over the board and with my concern for washing the pistons and so forth. They told me that all bikes are different and it comes down to how the bike is performing. If the bike is quick off the line, pulls well and has good performance, it doesn’t matter what the settings are. My dealer installed mine are high compared to a lot of people on here. So after speaking to Cobra and my dealer, I have quite worrying about it.
