Hmm, Powercommander website lists the part as "Power Commander V", part # 16-014. Power Commander V Support, Find Installation Guides and MapsIt wont be the Power Commander "V" though, since the Fury does not have O2 Sensors. Just FYII don't want you guys to think you got jipped
No, your right...Hmm, Powercommander website lists the part as "Power Commander V", part # 16-014. Power Commander V Support, Find Installation Guides and Maps
Am I missing something?
Yikes! That's like $850 in PCV and AutoTunes! Any idea if the cross over in the Cobra Swept Speedsters constitutes a 2 into 1 exhaust?... using two AT-200 kits to AutoTune each cylinder individually.
I would think so provided the O2 sensor was installed in the middle of the crossover if that is possible. Still, I'd check with Chris Kelly at Dynojet.Any idea if the cross over in the Cobra Swept Speedsters constitutes a 2 into 1 exhaust?
For the record the front cylinder is #2 and the rear is #1 possiblyAs my bike was getting tuned, it was mentioned that even though there are 2 fuel supply lines, it looks like the front cyclinder might be robbing some of number 2's fuel....As for the Power Commander V, you will need 2 O2 Sensors, one for each bank![]()
RSR Air/Fuel Ratio GaugeIf you surrender your bike to the hands of another they are going to stick a probe up your pipe to see what's going on. Long rubber tubes, pumps and gas analyzers. There's a lot wrong with this. First off, there is the nasty secret of reversion where the pesky 15 psi of outside air rushes back up the pipe to skew the sampling data. Then there is the fact that you have blocked the exhaust flow with your anally fixated device. Thirdly, there is the time delay of the sampling which means you are always "behind", no pun intended. Fourthly, the load on a dyno does not reflect what you see in the real world.
You are better off running the bike in the real world and watching the O2 display which essentially operates in real time. It will reflect your particular riding style and will save you a lot of money compared to those $200.00 to $400.00 dyno sessions. If dyno numbers are your mantra then do all the tuning in the real world with the RSR Air Fuel Gauge...Then put it on the dyno. The dyno operators are usually amazed on how well the bike runs..."What did you do to it?" is the usual response.
Brilliant web site and I'd say you are heading in the right direction!Here's some possibly relevant info from a company which makes the kind of gauges I've been interested in...
Here is a Dyno Chart from my bike running the Viper 2 exhaust. Notice the 2 numbers, each line represents either bank 1 or bank 2For the record the front cylinder is #2 and the rear is #1 possiblybecause the rear is first to TDC.
On this one I am guessing but I expect the PGM-FI is sequential and all the fuel from each injector should enter it's respective cylinder so I am wondering what you saw to indicate that the front cylinder is running richer than the rear if that is what you are saying?
Although your recommendation to use 2 O2 sensors with the PCV would be ideal and I am assuming you are including AutoTune, the system is not yet programmed for more than one O2 sensor on Metric bikes. Just Harleys get 2 for now.
And where in the world are you going to put that gauge???? It would look horrible on the handlebars and useless anywhere else.Brilliant web site and I'd say you are heading in the right direction!
Personally I'd go for this one since the Fury (or any other uneven firing single crankpin V-Twin) will always produce different results in each exhaust pipe.
For an excellent primer in V-Twin exhaust design have a lengthy read of their experience here:
RB Racing LSR 2-1 Exhaust Technology
It's a thing of beauty to the incurable gearhead. The rest can simply mount it temporarily until their baby is dialed in. Cheers!And where in the world are you going to put that gauge???? It would look horrible on the handlebars and useless anywhere else.
WOWHere is a Dyno Chart from my bike running the Viper 2 exhaust. Notice the 2 numbers, each line represents either bank 1 or bank 2![]()
HaHa, don't you wishWOW161 ft lbs of torque and 129 hp! Or did I get that wrong??? Could it be two seperate runs? BTW the Viper 2 into 1 with the longer rear pipe is a great choice for max ft lbs. That design is the official gearhead's choice
: form follows function and in your case looks very good as well.
