I did my valve lash today. Decided to take off the air filter box to get better access. When I went to put it back on, the 10 mm bolt at the bottom inside broke off while I was trying to tighten it back up. I noticed it was hard to get it out in the first place so I wasn't too concerned about it being tight going back in. It seems like that bolt might be overkill anyway and it it seems fine without it. It looks like it would be easy to get the bracket off and drill out the old bolt but I'm thinking it'll be fine as is. What do you guys think?
On another note, when I put on the rear intake cover, I think I might have stripped the bolt closest to the right side of the bike. I used a torque wrench and set it at 11 pounds. All the other bolts torqued up just fine. It did get tight but never seemed to want to torque to 11 pounds....it did torque to 10 pounds. Do you guys think that will be OK? I did back it out and try again but it did the same thing. Screwed in just fine but just wouldn't torque up to 11 pounds.
Thanks for all the help on here. This forum is great!
Doug
Doug
