Question About Shock Clevis
119 Views 5 Replies 3 Participants Last post by  krashDH
Hey Y'all...so the FSM states that the upper shock clevis needs to be torqued to 32 ft-lb...
When I torque it this much, that clevis does not rotate hardly at ALL. I mean I had to put it in the vise and grab the shaft of the shock and really push on it to make it move.
For those of you that have removed and installed this, should it be able to move easy? I'd think you'd want it to freely pivot a bit, but at this torque it just doesn't seem like it will.
But maybe it needs to be that tight? I'm installing the air ride and I just want to make sure it's really supposed to be that tight...
Reactions: 1
1 - 6 of 6 Posts
Without reading the manual for context I think they mean the nut for the holder rather than the nut on the bolt holding the shock.
Reactions: 2
The nut that fixes the shock to the frame is 47 ft-lb so this is the one that mounts the clevis to the shock eye
Reactions: 4
The arnott air shock bushing spins nicely torqued to 32 ft-lb. OEM won't budge at that torque. Learned that today
Reactions: 4
The shock should rotate freely, not be bound up on the frame. Binding means the bushing is too narrow for the clevis or the clevis ears are too thick.
Reactions: 2
Both the bushings in the OEM shock weren't to narrow. I think it's just a crappy bushing in the original shock
Reactions: 2
1 - 6 of 6 Posts
