1 - 8 of 8 Posts
ok looking at the scootworks raisers and the 3in extenders, wondering if I will need to change the brake line and cables. anyone know? or can i just run stock cables and line with raisers or extenders ?
plan on a cable and line upgrade to blue later but if i need them I'll wait little longer for the whole set up
pics please
pics please
with that combination yes you will need a longer brake line but not the others, there is enough wires tucked in the headlight but pull gently
With setup that you are looking for you WILL!!!! Need longer front brake cable. At VERY LEAST 3” over stock. Even then it’s very close.
I have the same set up . 3" over stock front brake line will work but really needs a couple more inches longer to fit ideal .
1 - 8 of 8 Posts
