1 - 3 of 3 Posts
Does anyone know how to take the radiator shroud off? I would like to put screen between the radiator fins and the shroud but can't figure out how to get it off.
Thanks for your heldp!
Spud
Spud
Here's a previous post by Tony Fury on this subject:
Let me clear up the sliding side to side for you.
If you look close at the factory grill, it has 4 plastic snap in connections.
Two on each side that are visible thru the grill.
You slide it from side to side to get them to pop out on one side at a time.
See attach picture up the back side of the grill. The arrows indicate where the plastic tabs are located.
Hope this helps..
1 - 3 of 3 Posts
