Fat tire
Nasty Sissybar
Kickout that front tire
Shotgun for the next mofo that runs yalls bike over
Nasty Sissybar
You are about dead-on what I want, including 12 ga. Add pipes that come way back and up with fish-mouths (ah-la Easy Rider) and you got what I want. Whether my guys let me do it is still in question.Fat tire
Nasty Sissybar
There's a reason some of us bought a 13k bike in the first place, more room for goodies on the tale end of our paymentsDon't think to many folks would want to spend that type of money on a 13K bike.
Well, if the bike is for a marketing tool, i would say go crazy. Try doing as much out of the box but flowing parts you can, but remember the pricing point you want to keep on products so it is more lucrative to buy. Figure most of the Exhausts are covered for general style differences (except for a long shot setup which i did with my jardine drags and tweeking the bracket), Fuel controlers are already out, You got the product edge on the tail light already, Seats are done, Forward controls only 2 companies have really dabbled (one is Higher priced the other is avg priced, but nothing economicaly priced), Sissy bar is currently Honda or custom only, B.S. Trim like mirrors, grips and pegs are close to universal.You are about dead-on what I want, including 12 ga. Add pipes that come way back and up with fish-mouths (ah-la Easy Rider) and you got what I want. Whether my guys let me do it is still in question.
Bottom line is this is supposed to produce sell-able products. Don't think to many folks would want to spend that type of money on a 13K bike.
Damn!Well, if the bike is for a marketing tool, i would say go crazy. Try doing as much out of the box but flowing parts you can, but remember the pricing point you want to keep on products so it is more lucrative to buy. Figure most of the Exhausts are covered for general style differences (except for a long shot setup which i did with my jardine drags and tweeking the bracket), Fuel controlers are already out, You got the product edge on the tail light already, Seats are done, Forward controls only 2 companies have really dabbled (one is Higher priced the other is avg priced, but nothing economicaly priced), Sissy bar is currently Honda or custom only, B.S. Trim like mirrors, grips and pegs are close to universal.
As a business tool with the bike i would focus on fenders, lowering kit options (Low and Mean has you beat to a spring though), Over rake kit, Sissy bar, different engine covers, or front lighting.
Other cool potential options would be peel and stick graphic wraps for the bike (fenders and tank), or a Faux flush mount gas cap or face for OEM honda cap to clean that up from honda's Funky ole thing
Fender struts for the Fury kit are YTD. When it comes to the fat tire kits, there are several good companies for options for what will fit within the stock framework (240-250) as you mention and they are relatively economical. Our kits go a little over-the-top with the ability to go to 360 and require a gearbox and new swingarm that we manufacture to offset the driveshaft. That ain't cheap. We realize it's not a mass-market item. The good news is that if you can change out your stock swingarm, you are 90% of the way to doing the project.I like the rear tire set-ups on your website for the VTXs. Will it be like those with the struts on the inside (not visible)? Will there be a lot of extra work that must done on this bike to get the 300 on? I seem to recall Sumo said that 250 was the max you could do without completely changing up the bike. If so, any chance you might do a 250 option as well to give us a choice for that upgrade for those that do not completely want to change up the bike?
Everytime I see that pic, I think, man, that just ain't the Fury. Talk about going in the wrong direction.Here's ape hangers... personally, don't think it looks right with a tear drop shape, but everybody has their thang...
good1. Rear fenders, honda did ok but it doesn't fit right needs to hug the back of the tire more..
changing the rake and getting the right length of tubes does that, so not neccissary if they just do an over rake kit by a few degrees2. Kick out the front, more rake, different triples.. Lower the front to match a lowered rear, fully slamed....
Intake adapters allow almost any harley intake, Cobra has one specifically for the bike too so would be hard for them to jump into unless they get something cheap and cool like the cobra3. cool intake that looks good, fits the chopper style and flows more air...
Look into what you want, It probably falls into a generalized aftermarket part like Grips, Pegs...4. cool kick stands.... short kick stands...
That is what i would kinda like to see (Kuryakyn used to make a set of lighted covers for the heads that i think would look cool)5. cool engine covers..
Would be expensive, tanks for sale have to be pressure tested, they would have to make atleast a tunnel and with the size of their company i dont think would have enough machinery to just stamp it out so your talking HRS of labor6. Larger tank, it's cool but too small for the bike makes the back of the bike look too big and more gas would be nice...
Not a bad idea, stock bars arnt bad though and riser options are available, Id rather see an exchange program where they drill them and internally wire them for (Price group 1) with all cables/wires except maby brake coming out behind speedo (For pricing group 2) But i also heard that some styles of bars with the resonating vibrations can crack if they get drilled for internal wiring7. different handle bars.
There is a HP Kit that is higher compression pistons, cams, and some other stuff if i recall for about 1k and its roughly 10 HP more. They did a write up on it in the Motorcycle USA project fury. Its actually for a vtx 1300 but the engines are near identical8. big bore kit.... hey we all want a little more motor...
These are some of my ideas....
