Im not sure however if your looking for slip on IMO the vance and hines look way betterAre these slip on exhaust tips and do you have to cut and weld these together before installing these tips..The instructions is showing you do. Anyone have these could give me some info and if they like them or not.
THanks Fellas![]()
I used a file one but the bottom pipe I had to hit a little with a grinder. I think I spent the most time trying to get the stock exhaust bracket wiggled out between the frame and swing arm.Love the sound and look of the Raw Reapers. hardest part was getting the OEM exhaust off the pipes and sanding for the Reaper collars. There is no wiggle room with the collars. Other than that......sound is very throaty and yes a lil ping in it.....but that sound is what sets it apart from the others and ...yes....its a good thing.
I concur; plus, they do a somewhat better job of covering-up the swingarm. Just my two-bits......................Im not sure however if your looking for slip on IMO the vance and hines look way better![]()
