I want to have a side mount l-plate get rid of the bottom crap.... How do I do this ??? Any easy ways???
It's very easy, if it was me i would remove the rear tail light section and use a dremel to cut off the metal tube bracket that extends down to the license plate (doesn't matter where you cut it just as long as it's not seen after you cut off the plastic for the license plate) and then use a cut off wheel to cut the plastic off that sticks down for the license plate, don't cut it to close because you want to be able to sand it down to get that smooth bottom below the tail light.
None of it is hard at all it's just a little time consuming because you want to take your time and make it as close to perfect as possible.
Another thing that would help you if you had one would be a belt sander and you could use that to sand the bottom plastic part below the tail light.
I know I had told you before to look for "******* license plate removal" but I looked at the thread and it doesn't actually show you step by step how to do anything, but once you remove the back fender and remove the tail light section you should see better what has to be done.
