1 - 11 of 11 Posts
hello guys, newbie on a Fury. I need to add rear footpegs but can't see where they should mount?
If your bike is a newer model, Honda stopped including rear passenger pegs and
rear seats a couple years ago. Or if used, maybe the previous owner removed them. You'll need to order the peg brackets from Honda.
Discussion Starter #4
thanks, I have an older bike, but no rear pegs. could you get me a better view of the mounting points? I guess I will have to order in.
You must have bought your Fury used...and the previous owner must have cut off the welded on to the frame footpeg tabs.
It's pretty obvious , and very ugly where Honda is leaving the welded mount, but at least they are there should someone wants to add pegs AND rear seat.
They're not welded on. Two bolts on the backside. View attachment 235786
Good info...did not know. Thanks.
I just went out in the garage and checked it out , and you are right.
The original poster has to reach behind the frame and find the 2 mounting holes.
I've been to the Honda showroom and seen the exposed brackets...surprised that they leave them on and looking ugly. Seems like the sharp edges would be a liability.
Yeah...l took mine off, cut the Honda peg mount off, had them chrome plated, and installed some Harley style peg mounts so I could use pretty much any pegs I wanted.
[/QUOTE
There are 2 peg support mounting holes located approximately 4" above the frame on both sides in front of the rear wheel and hidden in the wheel well
1 - 11 of 11 Posts
