There is susposed to be two adjustments for the rear suspension... I found the first one, the large knob on the under the right side cover (36 clicks). But what about the other??? Any help finding it???
in a nutshell.... if u soften the shock all the way it has less resistance and goes thru its stroke faster(hence if your riding 2up or heavier than standard rider ,usually somewhere around 170lbs-yes that is a guess-youll want it set to harder . there is a rebound on the bottom which controls how fast it rebounds or returns,my thinking is if u soften the top too much (compression) and hit a large bump the shock will compress and if the rebound is to hard it will rebound the shock fast for a kidney bouncing ride. if u can balance the two for your weight it would be at its bestCan someone explain in detail the ride characteristics of different combinations of the Fury's rear suspension control settings.
God Bless our Military! ... Semper Fi!
I know its been a while, but sometimes thinking smaller isn't the best option. I found a long flat like 14" works very well.I found that a dime works great to get in there and adjust the bottom screw. I have big hands and could not get in there with a stubby screwdriver.
