I think RSS just replaced his with 15k on the stock tire.
i put a new metz on and went to the dragons tail in tenn.pick up a screw,plugged the tire and rode it home . replaced it with 1650 on it.i prob would ride it alone,but not with the wife onboard.I replaced one with less than 1k lol, damn screw
i tried to sell mine on here with less than a 1000 miles on it.no one wanted it.good luck.If anyone is interested I have a stock tire for sale -- cheap.
T
Cause the Metz makes the back end look bigger and fills it in more, they are the same size but Metz gives the appearance of it being bigger, this has been verified with a side by side test between several different bikes when we all rode together. Also, Shane or CBfury got 16k on his Metz as well, so it will wear just the same as the Dunlop. Metz also feels as though it sticks to the ground a little bit better, but that may be because they are new tires to me... I'll let you know after a few thousand miles. So, basically... if they are the same size and basically cost the same, but they give you the look of a bigger tire without having to go to a bigger tire or different rim, then it's a pretty easy choice actually.Oh ok so you decided to just change both of them huh. So why is it that everyone is changing to the Metz tire instead of the same kind that comes on the bike, any special reason? Not that I'm in need of any tires on my bike since I only have like 800 miles on mine lol, but then again my 07 dodge ram only has 19,000 miles on it, damn deployements.
Yea, just did a back road ride this last weekend and I felt as though I was corning on a dime, sometimes forgetting the Fury has its limits on the turning radius... I was also riding 2up so, I also figured the extra weight in the back might have made a "feel" difference... will have to take the roads on by myself to really see the difference. Figured it was the tires, but the Dun's also gave me pretty much the same feel to the corners, with a little stiffer result.if you ride hard curves in the mountain you will see the diff.the metz want give you the bump slip in a hard curve.i ride with a group that does a lot of mountain rides.the first thing we do is change to the metz.
i found out i dont have to fight the curve anymore.with the metz you just scoot around it.you will see.Yea, just did a back road ride this last weekend and I felt as though I was corning on a dime, sometimes forgetting the Fury has its limits on the turning radius... I was also riding 2up so, I also figured the extra weight in the back might have made a "feel" difference... will have to take the roads on by myself to really see the difference. Figured it was the tires, but the Dun's also gave me pretty much the same feel to the corners, with a little stiffer result.
I can check tomorrow at workDoes anyone know the new tread depth of the stock fury front and back tires? Would appreciate it if someone with a depth guage and a new bike would check this. Unfortunately there is no Honda dealer near me to allow me to run down and check myself.
I found it was fairly easy to determine wether you can make the next long trip by comparing current tread depth and mileage with new tread depth.
Thanks in advance to anyone who can get a measurement.
