Rear tire ?
2637 Views 16 Replies 11 Participants Last post by  460brevill
To Patch or Not To Patch???that is the question
1 - 17 of 17 Posts
Since you ride at just under the sound barrier, I would play it safe and buy a new tire.
is that an indention or is it the nail head I see indented? I would buy a new tire. In your case a run flat :)
damn that sucks too because there is lots of tread left on that tire.
Might as well go ahead and put the Sumo kit on now.
New tire time :(
Too much is riding on those two tires to risk it. Bite the bullet and buy a new one!
well its a toss up I think, between the SumoX and a new tire....
but the wallet says plug n patch. so we have a winner
Yup... least you decided and I figured you'd go this direction with your job situation... but, later on if you change your mind, go with a Metz... you won't be sorry and you may rethink the SumoX thing as the 200 Metz alone gives it a bigger appearance than the Dun.
:D
I was hoping for plug and patch advice really, I have a full tire shop here in the garage and at my disposal, but he is a car tire man, he wasn't 100% sure about motorcycle tires.
My father in law just got screwed a couple months ago on his VTX1800. He plugged it and has had no issues. He is not the slowest or smallest rider either.
Everyone has different luck. A few years ago I put new tries on my H-D Ultra Classic & ran over a nail with the rear tire that very same day. Against my better judgment I plugged the tire with an $8.00 plug kit from AutoZone. I checked my tire pressure often & kept an eye on the plug. After around 9000 miles the cords were showing threw & the monsoon season was approaching so I decided to install new tires again. I personally never have had a problem with a plugged tire. However, for safety reasons, I recommend that you have a certified Honda tech install the best quality tire that is recommended for your bike.
That sucks... atleast you have more than 600 miles on the tire... had to replace my stock tire real early because of a sheet metal screw... I would replace the tire and save that one as a back up, but that is JMO
AND..........DONE!!!!!
Mike 1 - Tire 0
Well after a $5 uni-patch and a few hours
I win!!!!
It didn't whoop me!!
Tho I have never tore apart a motorcycles rear end. I will admit I had a couple WTF :confused: am I doing moments and a 1 hr nap to get away from it. I am rolling again, and that is all that matters. :D
Thank you all for your input :)
Mike
what cb said.weigh it out 200.00, you life
1 - 17 of 17 Posts
