I recently installed my Cobra Speedster Swept pipes myself and decided to remove the baffles to see just how loud LOUD can be.
Anyway, I found removing the little bastards to be pretty difficult. So I thought I would share some tips on how I finally got them out.
#1 - Before you start, go to Lowe's or wherever and purchase the following items unless you have them at home already:
- 10 1/2" Nail Pry Bar. Don't fart around with a bent clothes hanger or anything like that. You'll thank yourself later: http://www.lowes.com/pd_99322-16878-NP1005_0_?zipCode=75070&firstReferURL=http://www.lowes.com/pd_99322-16878-NP1005_0_%3FproductId%3D1204857%26Ntt%3Dnail%2Bclaw%26Ntk%3Di_products_cascade%26pl%3D1%26currentURL%3D/pl__0__s%3FnewSearch%3Dtrue$Ntt%3Dnail%2520claw$y%3D0$x%3D0&catalogId=10051&catalogId=10051&productId=1204857&pl=1&findStoreErrorURL=StoreLocatorDisplayView&selectedLocalStoreBeanArray=[com.lowes.commerce.storelocator.beans.LocatorStoreBean%4023798ba,+com.lowes.commerce.storelocator.beans.LocatorStoreBean%407df58ba,+com.lowes.commerce.storelocator.beans.LocatorStoreBean%407fdd8ba,+com.lowes.commerce.storelocator.beans.LocatorStoreBean%40500618ba,+com.lowes.commerce.storelocator.beans.LocatorStoreBean%40502498ba]¤tURL=/pl__0__s%3FnewSearch%3Dtrue$Ntt%3Dnail+claw$y%3D0$x%3D0&Ntt=nail+claw&URL=TopCategoriesDisplayView&langId=-1&langId=-1&storeId=10151&storeId=10151&Ntk=i_products_cascade
- WD-40.
- Gorilla Glue. I pulled the rubber handle right off the nail claw on the first try. The GG worked great, you just have to let it set up for about an hour.
- Small phillips screw driver. You'll need this remove the two small screws that hold the baffles in the pipes.
#2 - Try the baffles removal with cool to cold pipes. I read a few things about doing this with warm pipes, and I tried this, but quickly remembered metal expands when heated. Your experience might differ, but when I attempted removal with warm pipes, all I got was alot of sweat and hot hands. If you think heating will help, its easier to heat your pipes than cool them, so try the cold removal first. I'm just sayin'...
#3 - Gorilla Glue the rubber grip of the nail claw on. Trust me.
#4 - Remove the single screw on back side of each pipe which attaches the each baffle to the inside of the pipe. I removed my screws prior to exhaust system install because I figured it would be easier to get to them then. I know, I know...
#5 - Shoot a good amount of WD-40 into your baffles. Don't over-do it, but get enough in there to do the job.
#6 - Grab your bad ass nail claw and lie down behind your bike (if you're a righty) on your right side, with your right knee on the back tire. I put my left foot on the wife's SUV running board next to me for some extra leverage.
#7 - Run your nail claw inside the pipe of choice at an angle so you can hook it behind the area where the screw you removed earlier would fit, on the inside, obviously.
#8 - Use some elbow grease, and start pulling. I found that some harder yanks in the direction the pipes curve downward got the baffle moving better than a sustained pull.
That's it. You should have Cobra 2 pipes sans baffles. Upon starting my bike, I realized my time and little money spent to get them out was WELL worth it. It's really the same tone and bark with baffles installed, only LOUDER!
I'm not saying this is the best way, or mechanics way, or anything else. This is just the method I used to finally get those little boogers out. Any criticism, compliments, or otherwise is always welcome.
For some of us, the only way to learn is to DO, and learn as you go.
Hope to see ya'll out on the road soon with some loud-ass pipes!
- WD-40.
