Are you talking AXLE bolt or ROTOR bolt ? The AXLE is 22mm, the ROTOR to the wheel is 6mm allenDoes anyone have any tips/tricks on removing the front rotor? Also if anyone knows what size the front rotor bolt is? I know the rear is 32mm, not sure of the front.
Ok it is stupid question time...Jack the bike up and secure it. For the front, Loosen the left side pinch bolts, unbolt the axel from the left side , leave the bolt in with a few threads, loosen the right side pinch bolts, I use a rubber mallet to drive the axel to the right side , hitting the bolt head, remove the bolt from the left and pull the axle out to the right, hang onto the wheel as you pull/wiggle the axle out, the wheel/tire will drop down. Make sure you note which spacer goes on which side. (Right/ Left side is as you set on it)Do not touch the front brake lever while the wheel is off, or you will have to pry the pads apart to reinstall.
Just looked it up, and they are the same on the Fury, most of the other Hondas are diff, so it is just a habit with me to seperate them left and right. Sorry for the confusion.Ok it is stupid question time...
Are the front wheel spacers different sizes from left to right? I didnt pay much attention when I took my front wheel off but everything lined back up on re-install so maybe I just go lucky.
