Hi all, been looking into building a set of 1.5 inch handle bars to replace the existing, nothing wrong with the originals , but I just like a bit of individuality and the bars would be any easy build or even fairly cheap to buy. Why didn't Honda make the mounting holes the same as the Harley - the choices would be endless.
The bars aren't the problem; unless you keep the first section similar to the originals the speedo either won't fit or will look completely out of place.
The QUESTION: Has anybody fitted an aftermarket DIGITAL speedo? I need to know if these will work with the Fury speedo signal. Also can someone tell me the color wire that is used for the speedo signal and I can then see what it is and were it is derived from.
