This was posted back in June, no post on this product since, and u just cant tune it away. Can it work, who knows? Being a little older, I have learned not to try to make a ham sandwich with a chicken. I have read all the stuff on this posted on the Forum, u go read it, good luck. However, if u blow your engine, then u will know why Honda put a rev limiter on it. Good Night! Good Luck!
1 (
permalink)
Clueless
Breaking the 100 MPH Limiter
First I am not, nor do I want to. 2nd, I said last year that a Speed O Healer may be able to do it, so since it came up AGAIN, I emailed Heal Tech Electronics about it, they now list the VT1300CX as available and got this answer,
3rd, don't blame me if you it works and you mess pants
so anyone wants to try, here is your chance
Sent: Sunday, June 20, 2010 15:34
To: [email protected]
Subject: speed o healer
I have a 2010 Honda VT1300CX (Fury), I was wondering if your speed o healer would by pass the built in speed limiter on these bikes as they do on other models, thanks
John
Hello John,
Thank you for your email - that's a good question.
IF the bike does have speed limiter, probably the SpeedoHealer can be setup to remove it.
To check whether the bike has speed limiter or not, one option would be to put it on a dyno and see if the indicated top speed is higher or not than on the road.
If the bike has speed limiter, the top speed is the same even on dyno where there's no wind resistance.
If you wish to try a SpeedoHealer unit we can offer one with money back guarantee in case it does not work as expected.
Kind Regards,
/Norbert
healtech-electronics.com
"Common sense is not so common."
* Voltaire, Dictionnaire Philosophique (1764)
OOPS
HealTech Electronics Ltd. - Makers of the SpeedoHealer, GIpro, X-TRE, OBD Tool
