1 - 3 of 3 Posts
I’m looking to buy a custom 26” front tire but I do t know what size the rotor should be or where to purchase it.
I could be wrong but I don't think the rotor size changes with the wheel size. Depending on the wheel you may even be able to use the stock rotor if you want
Also just a heads up. I found out the hard way. You can get some pulsating on the front brake with aftermarket polished rotors. The polishing process can make the rotor slightly off. I was told that it should get better after some use though
1 - 3 of 3 Posts
