1 - 5 of 5 Posts
2011 Fury
sorry if this has been discussed previously BUT there’s so many posts I can’t find the info I’m looking for. I want to put the S&S air cleaner on my Fury;
1) What kit works with the accutronix adapter?
2) Do I need the adapter?
Ironically this just got delivered about 20min ago. (Keys for size reference)
Product Body jewelry Jewellery Font Electric blue
It's ment for a sportster but if you can find or fab an adapter like this
Hand Crankset Bicycle wheel Automotive tire Finger
Its almost a direct bolt on. I will have to do some minor modifications to the cleaner (pluging a hole, adding a barb for a hose and might add the drain tube like on the stock cleaner)
The cool thing about this one is it can be installed like the stock cleaner or turned like the s&s.
Down side is i need to get a rain sock for it because how open it is.
Audio equipment Communication Device Magenta Musical instrument Gadget
I believe the Accutronix adaptor works with any 99-13 Harley with the CVI carb. I tried a Kuryakyn intake with it but found that it stuck out too far for my liking. I'm currently using it with the Forcewinder intake. I ended up not using the outer ring where the Pair valve hose and crankcase breather connect so I just put some breathers from O'reillys on the ends of the hose.
1 - 5 of 5 Posts
