1 - 3 of 3 Posts
Hi all,
Happy new year to everyone.
Waiting for my 2010 Fury to be delivered so thinking ahead.
Where do people site their sat nav please ?
And where is the best place to pick up a switched live to power it from please ?
As always - thanks in advance.
Cheers from the UK
I use SP Connect phone mounts in all my vehicles. Similar, but much better, than the quadlock system. I have the chrome antivibration mount on my handlebars. Assuming the satnav is powered by a USB connector, you could run a direct connect from the battery, under the tank, to the neck of the frame, ending in either a USB female connector, or a 12V DC. If using 12V DC you can find little 12V DC to USB converters to plug into that.
Hi all,
Cheers from the UK
I use my phone for the navigation and purchased this bracket:
and I installed a USB port hotwired directly from the battery and installed at the end of the gas tank where it meets the handlebars:
The wire is long enough to run it from the battery, along the frame, under the gas tank
1 - 3 of 3 Posts
