1 - 7 of 7 Posts
Let me start by saying that I'm no wrench. I need to know how to remove both the rider and passenger seat. How do you remove the rear bolt on the passenger seat? Do you wrench from under the rear fender? I know you remove the strap's allen bolts. then what. A step by step procedure would be greatly appreciated, I ordered the vector seats. Thanks.
If you pull up on the seat from the rear you will see an Allen bolt. Then if you pull up on the driver seat on each side just before the passanger seat you will see the two bolts lthat hold on the front seat.
let me start by saying that i'm no wrench. I need to know how to remove both the rider and passenger seat. How do you remove the rear bolt on the passenger seat? Do you wrench from under the rear fender? I know you remove the strap's allen bolts. Then what. A step by step procedure would be greatly appreciated, i ordered the vector seats. Thanks.
the allen wrench they give you is inside the cover where you place your key. (the wrench isn't worth a crap, strips easily)
also caution pulling the pins out of the cover where the allen wrench is. (these are plastic, and may break) once you find the wrench. Place place you two pointer fingers under right or left rear of seat and pick up pade you will see the screws. Just be cautious because they feel like they are torqued down and you will scratch the paint if your not careful. Good luck!!
1 - 7 of 7 Posts
