Has anyone seen a side mount for the Fury with an integrated tail light?
Does that have the tail/brake integrated into it?Required custom mounting though....
It is the Kuryakyn side mount plate
Check with Accutronix. They have some for other bikes, or you can buy a small light like the one in your picture and make a bracket off of the side mount. Here is the current side mount from Accutronix on my bike with the Raw designs rear tail light.
[/IMG]![]()
[/IMG]![]()
It was very easy to install as long as you are comfortable making the electrical connections. I don't plan on changing out my rear fender, so It was a no brainer for me. L&M is working on an air ride system for the Fury right now, so hopefully it will be lowered by next riding season.This is what I was leaning towards, but if they come out with a fender that isn't compatible with the RAW rear light I was thinking I will need something else. Was the RAW light easy to install? I really like the look, but once you pull off the factory rear taillight assembly the bike just begs to be lowered.
Thanks for the info. I'm looking forward to lowering the bike as well. I think that rear wheel needed to definitely be tucked up in quite a bit more. Progressive Suspension said today that it would be at least fall if not later before they have something. Air ride is much cooler anyway.It was very easy to install as long as you are comfortable making the electrical connections. I don't plan on changing out my rear fender, so It was a no brainer for me. L&M is working on an air ride system for the Fury right now, so hopefully it will be lowered by next riding season.
I love air ride!!!!!! Should help the bike look a little more custom.Air ride is much cooler anyway.
lol, It gets low enuff when I put my big ass on it!It was very easy to install as long as you are comfortable making the electrical connections. I don't plan on changing out my rear fender, so It was a no brainer for me. L&M is working on an air ride system for the Fury right now, so hopefully it will be lowered by next riding season.
dang that sucks! im debating on them or ones with turn signalsYa I saw those after I bought mine! Kicked myself in the rear after when it was too late! LOL!
