Really, if that is what you want, I would only order some from someone who has them in stock, and with that stipulation, if they have to order them, fine, have them order them first and then give you a call, and then you can pay when they are in.. I believe you would want the heat shields, ( see thread mayhems are on by Fury 27, 06/30/10, to see black ones ) which come in chrome or gloss black. Do not pay anybody up front unless they guaranty they have them in stock and with your name on them, and pay by CC. I would not trust ordering from Fuggin directly. That is, if that is what you want. You must error on the side of caution!
Posted by Jimmy Ferris
Fuggin Mayhem Exhaust
First let me be PERFECTLY clear. I think the Mayhems look the BEST of any aftermarket exhaust. The sound is PHENOMENAL!!!!! Plus, I am very pleased with Fuggin and their customer service. In other words, no complaints from me. ( MENTAL says, things have changed with Fuggin since Jimmy posted this, caution, caution! )
Jimmy Ferris, continued,
I have already changed to the Cobra Swept exhaust. So why did I change?
Two reasons.....the Mayhem design doesn't allow the pipes to wrap around the engine. As a result they protrude out quite far and it is VERY EASY to burn your leg (or jeans or boots). Secondly, again because of the design, you cannot remove the plastic cover to access the fuses or adjust the ride of the shock. (You actually have to remove the exhaust pipes to get to that panel.)
