I have the Window levers and love them! Would fit in perfect with your theme!
yep...they are on my list...thanks
Looks great!I have the Window levers and love them! Would fit in perfect with your theme!
Fury10,View attachment 743 side view...flag holder fab'd from old one I had...I'm a PGR member
I used another flag staff I had. Cut the bottom off smooth...tapped it to fit a 10mm? (I forget the fender hole size) screw...bought the correct size screw...cut the screw to the correct length...inserted the screw in tapped hole...mounted it to fender hole (solo seat)...viola. You can use the original fender screw, but I thought I might need it later. I also sanded the cut sharp edges of the staff and used a rubber fender washer to eliminate scratches.Fury10,
Where and how did you attach your flag holder? I'm in the PGR too and would like to ride my Fury on a mission.
I live in Seaford...you?Fury 10 where in LSD do you live I'm in UFD
I'm in ClaymontI live in Seaford...you?
Thanks for the information Fury10, I'll try to adapt one for my bike.I used another flag staff I had. Cut the bottom off smooth...tapped it to fit a 10mm? (I forget the fender hole size) screw...bought the correct size screw...cut the screw to the correct length...inserted the screw in tapped hole...mounted it to fender hole (solo seat)...viola. You can use the original fender screw, but I thought I might need it later. I also sanded the cut sharp edges of the staff and used a rubber fender washer to eliminate scratches.
I'm in Claymont
