Sometimes Engineering and Machine Shop Friends are Good to Have
574 Views 27 Replies 7 Participants Last post by  krashDH
So my coworker and I are both engineers, truck and car enthusiasts, etc. Except he's got a mill and lathe in his garage and I don't.
Branching off from my other thread where I'm looking for that black shock clevis Honda refuses to sell separately, I have had ZERO luck finding one and you can't use the one off a sabre/stateline either because it's a different shape.
So in 5 minutes I reverse engineered the bracket and modeled it up in CAD for him but we obviously have to design a little bit differently because we don't have access to that exact M12x1.5 stud. So here's the idea we came up with:
Wood Household hardware Composite material Auto part Aluminium
Obviously the smaller hole is for that anti rotation pin. That just punches out of the original clevis no problem. You can see the larger hole(s) one is a thru for the m12 stud and the larger counterbore is for the "head" of a stud. Now, he's just going to make a custom stud for me with a head that fits nicely in that counterbore. The stud will press fit into that thru hole (there will be an interference shoulder on the stud) so it won't rotate. But we're going to take it a step further to ensure that the stud stays where it needs to when torquing down.
Where the green circle is, and 180* from it on the other side, there will be a drill thru and tap (or the other option is just a drill thru all the way) for a threaded set screw. We'll drill so that the center of the small tapped hole sits right where the head of the stud meets the counterbore. This will essentially cause a "half circle" to be on each feature. Then we'll run a tap down through there (if we tap) and install a set screw in each location. Now the pressed in stud not only has the press fit but if for some reason that failed, it's locked into position.
If we don't (read: can't) tap that material, we'll just drill thru or blind depending on what we decide and press fit a pin in those locations. It will do the same thing for counter rotation.
The reason we might not be able to tap is this is some material scrap we got from work. It's 15-5 PH H1025 stainless steel. This stuff is very hard to machine, let alone tap with a small diameter tool. If you're wondering about material specs, it has an ultimate tensile strength of 206ksi (206,000 psi), which is about 3.5x the strength of mild steel which the OEM bracket is stamped/bent from. This thing is going to be STOUT.
In in finishing thoughts, Honda, get your S together. It's a bolt on part to a shock that should cost us $15 to buy. IIstead you're nice enough to "include" it with a new $700 shock.
  • Wow
  • Helpful
Reactions: 5
21 - 28 of 28 Posts
Yup, wife bought SQ5 and a Shih Tzu with my money, she can’t say squat to me when I buy that hellcat this year
  • Haha
  • Wow
Reactions: 5
I'm pretty sure that's not how they see it.... 🤣
  • Haha
  • Wow
Reactions: 5
I'll be interested in your reports on this
Reactions: 2
For sure. Wish I could start getting it set up but still waiting on the switch, supposed to be here tomorrow
Reactions: 3
A nice shot of this beauty before installed:
Underside design:
Looked nice installed:
Whoops...buddy was .200" long on the thread. Interfered with the tank:
Chopped it down to size and ran a die down the threads:
So, what I found out, is M12 x 1.5 isn't very common. They don't have those Fuse Rashi spring loaded locking flange nuts like the OEM one (M12 x 1.25).
It's also rare to find ANY type of locking nut for M12 x 1.5 that has an integrated flange. But my Google Fu was strong yesterday and ended up finding a nyloc nut that Polaris uses on their suspension. M12 x 1.5 and has a nyloc insert and built in flange. For now though it's just a standard nyloc nut and washer that aren't one piece, but it'll do.
Great looking custom part!!! It's a shame for it to be tucked up in there so far out of sight, but good to know that a quality piece is there.
What happened to the paint? Looks like a crack in that last attachment?
Reactions: 2
Just a weird reflection? In the tank photo?
Reactions: 1
It was the very last pic that looks like the attachment isn't inline, but just attached to the post...
Reactions: 1
Ahh oh yeah. I was gonna post that up on another thread to ask for advice on that. Didn't realize it made its way onto this thread attached somehow. There's a crack in the paint right there. Looks like it almost is clean from a blade. Not sure if there's a good way to fix that or not...it hasn't gotten worse since I've owned the bike but it's been there the entire time. What's odd is the clearcoat and paint in that area as you can see is fine, there's just that odd split...
Reactions: 3
21 - 28 of 28 Posts
