Good to know Mac... I am looking forward to see how it will perform along with taking out the pairing valve... thanks for the infoI have the NGK Iridium in my other bikes and they are great. I'll change to them when the time comes to replace the plugs.
Have my covers for the pair valves with the "nipples" in... maybe Wednesday I'll take out my pair valvesGood to know Mac... I am looking forward to see how it will perform along with taking out the pairing valve... thanks for the info
What does your pair valve covers with nipples have to do with spark plugs? Maybe you should have put it under the pair valve thread... You may get the attention that you are seeking for that info... PoserHave my covers for the pair valves with the "nipples" in... maybe Wednesday I'll take out my pair valves![]()
nah, was just bored and drunk, so I decided to post to your tread...What does your pair valve covers with nipples have to do with spark plugs? Maybe you should have put it under the pair valve thread... You may get the attention that you are seeking for that info... Poser![]()
How are the plugs doing? Notice any difference in performance, miles before light?Is anyone using the NGK-DPR9EIX-9 NGK Iridium Spark Plugs? Found them on cruisercustomizing.com for $10.75. I have ordered them but just wondering if anyone has done this performance change. Thanks for the feed back.
Honda will use what WORKS/PROVEN and what is cost prohibitive! Fury manual says you can use high performance NGK or standardi look at it this way if honda or any other company thought those plugs were to be better they would have put them in there bikes from the factory. I still the factory NGK plugs are the best. the e3 plugs might improve alittle but i dont see spending the money until the factory plugs need to be replaced.
Actually, go back to the -6 heat range. With our relatively-low compression ratios, a -7 is probably too "cold", is not burning clean, and causing your "stuttering". When they say "high-speed-running", they mean CONSTANT high-speed-running (3/4 throttle and above). If you're running town-and-highway (like all the rest of us), you'll have intermittent fouling problems with the -7's, -8's, and -9's. Plus, Iridium Plugs, due to their construction, run cooler than conventional's. FWIW.....................I have been having a small studder issue between 85 and 90 mph... was thinking that it was with the plugs so was just moving things around to eliminate the issue. I was running the 9's so the where a little different but once I get this studder problem fixed I will be going back to the 7's.
